Smart plug
- Re: Smart plug
Smart plug
29-12-2020 6:37 PM
I have a couple of smart plugs and for the life of me can't get them connected up.
They connect on another WiFi elsewhere at another house, different router.....but not my plusnet router
Re: Smart plug
29-12-2020 9:11 PM
Are the two mains sockets on the same ring main, and are you using an extension lead?
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Re: Smart plug
29-12-2020 9:15 PM
Try factory reserting them and set them up from scratch.
Re: Smart plug
29-12-2020 10:53 PM
That was it..... extension lead.... thank you.
