Smart plug
howardl
Smart plug
I have a couple of smart plugs and for the life of me can't get them connected up.
They connect on another WiFi elsewhere at another house, different router.....but not my plusnet router
3 REPLIES 3
198kHz
Fixes: 41
Re: Smart plug
Are the two mains sockets on the same ring main, and are you using an extension lead?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Fixes: 419
Re: Smart plug
@howardl
Try factory reserting them and set them up from scratch.
howardl
Re: Smart plug
That was it..... extension lead.... thank you.
