Small but annoying problem with clickable links
pimpernel
Using Firefox and Thunderbird.
Up till last week, clicking a link on an email opened the (closed) browser AND then opened the link.
Now the first click simply opens the (closed) browser. I have to click the link a 2nd time for the web page to open.
I had a recent encounter with some crummy software - FISSA, which kept installing itself as my home page when I simply use blank:blank.
Got rid of that, which I think has caused this 2nd problem. Any solutions welcome
5 REPLIES 5
shutter
Fixes: 65
Re: Small but annoying problem with clickable links
Try using CCleaner ... and then use the Registry Cleaner on the left panel of CCleaner,  to see if it shifts "whatever it is" ,...
pimpernel
Thanks for the recommendation.....unfortunately....although Ccleaner removed a pile of stuff, the problem persists even after a reboot.
I'm stuck with this, I suppose, as a "feature" for next 12 months when I am upgrading.
Unless somebody can suggest anything else.
shutter
Fixes: 65
Try "Malwarebytes".... and "Eusing Registry Cleaner"....
Eusing Registry Cleaner usually finds stuff that CCleaner leaves behind !...
(Both FREEEEEE !..so no cost to you !)
pimpernel
Nope - that don't find anything either.
Seems to me that a simple change to the registry is needed somewhere - but where?
ejs
Aspiring Hero
Fixes: 25
Have a look at http://support.microsoft.com/kb/175775
You may have to reset everything and have Internet Explorer as the default web browser, then when things are fixed you will be able to change that back to Firefox.
