Slow XP Boot
penfold
Fixes: 5
Slow XP Boot
Just reporting on a thread I had on the old forums ( thought they were exporting all the old threads to this new site!?!),  I ran bootvis, and this appears to have vastly improved the boottime, from over a min and 1/2 to around 40secs before XP is useable. Just a thought as well, the HDD is not in a caddy, its just plugged into the connector, and when you look, it does sag a bit. I will try and get a proper caddy for it on E-Bay Wink
4 REPLIES 4
7up
Fixes: 17
Re: Slow XP Boot
Quote from: penfold
E-Bay Wink
Buy it, Love it, Sell it!
iainmacmillan
Re: Slow XP Boot
could also depend on the amount of programs/services starting from boot-up.
Start->Run->MSCONFIG will give you a range of tabs, last one is the Startup tab, which will tell you whats running, and what might be causing the delays.
Also make sure you regularly defrag your drive, as it too can cause slow performance.  Diskeeper is the best package, but there are free ones out there you can use.  The in-built XP defrag and made by DK, but its a very basic (almost useless copy).
agloco
Re: Slow XP Boot
What i have found that on xp machine if you have windows update switched on to do it itself it can slow your pc a great deal.
I just switch it off and check it every couple of weeks.
M
anderson
Re: Slow XP Boot
Following on from reply 2 make a note of the items in the startup menu in msconfig then go to www.sysinfo.org. Here you can search and get details of the items along with advice on whether to remove from the menu or not.
