Slow POST sorted.
Fixes: 50
Slow POST sorted.
For a few days now my PC has been sticking on the POST screen for 2-3 minutes before finally starting.
This usually occurred when I came home in the evening and fired it up.
I finally cracked the problem this evening....
My daughter was leaving her iPod Nano plugged into a USB port when she shut down the PC.
I removed the iPod and away it went.
Tried a shutdown and startup and it's fine.
Don't know if this has been mentioned before as the forum search is no good for......searching the forum Sad
Customer and Forum Moderator.
Fixes: 57
Re: Slow POST sorted.
It's not much good for anything else either  Grin
Fixes: 9
Quote from: Strat
You mean people still use forum searches? Wink
Fixes: 50
I very much doubt it unless it's their first time.
I searched for something only this morning I'll have you know.
I'm still looking for it too....
Fixes: 4
Can you find it with this?
http://community.beta.plus.net/google/
Fixes: 8
I've tried that and it is totally and utterly useless as a forum search.
See http://community.plus.net/forum/index.php/topic,881.msg483893.html#msg483893
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Doesn't offer useful enough functionality.
Can't see enough of the posts in the results to tell me if its the post I want, and can't order the results how I'd like either.
Google weighting might work OK on the web, but on a forum discussing changing configurations/options etc, its fairly important to know you've located the most recent advice on a matter.
I'll concur with that.
Giving more 'context' to the search results, and allowing the posting date to carry more 'weight' with the relevance would actually make it much more useful.
B.
Fixes: 50
I'm searching for my OT....can't find that either Huh
Fixes: 8
You can't search by user.
Fixes: 50
I wonder if there are any plans to fix this search in the future or replace the button with something useful. Undecided
Suggestions on a postcard to......
Fixes: 4
Colin has been trying to fix the search, but we've distracted him with the new skin.  When ever we remind him about the search, he swears a lot.
James
I've only ever heard Colin swear once.  him swearing "lots" is quite a scary prospect.
Fixes: 50
I thought it went with the territory Wink
It does in my office...
