Slow O E and Google Chrome
stathe
My O E and Google Chrome are slow to load, are there programs I can run to speed them up ?? Thank You
1 REPLY
Fixes: 24
Re: Slow O E and Google Chrome
Outlook Express:  Empty the deleted items folder then compact all folders.  Be careful not to switch off the computer before this finishes.  If it takes a very long time, look at archiving your older emails.
Google Chrome:  Try Settings - Extensions then disable any extensions.
