Slow Internet Connection after changing to Windows 8
casioman
I just got a new computer which uses the Windows 8 operating system. My old computer used Windows Vista Ultimate and was fine. However I find that the internet connection on my new computer is slow and sometimes disconnects altogether and I wondered if this is because of Windows 8. I note also that plus net assist does not work with Windows 8. Maybe I have erred in getting Windows 8 but it seems to be the norm.
5 REPLIES 5
Oldjim
Fixes: 63
Re: Slow Internet Connection after changing to Windows 8
To check - does the old computer still work OK - this is to ensure that it is a Windows problem not a line or router problem
casioman
The change of computer was forced upon me as the graphic card went and being a laptop it was not economical to have it repaired.
My Ipad is not affected at all - still fast. The connection is wi-fi so it must be the OS I think.
Oldjim
Fixes: 63
Moved to Windows Board
Are you using a Security Package on the computer
tijara33
Fixes: 6
I'm using W8 & it isn't causing me any problems. I upgraded from W7 last year.
ejs
Aspiring Hero
Fixes: 25
I'm assuming the new computer contains new wifi hardware - perhaps check if any newer wifi drivers are available.
