Slim Desktop PCs
Luzern
All Star
Slim Desktop PCs
XP Home SP3
No not the ones in side the Copshop filling their reports: they'll be getting fatter. Wink
More seriously I am musing on replacing my 7 yo machine with something more up to date, which will be better for jobs like photo editing and slideshow making as well as the routine uses.
I have seen a few Slim Desktop PCs that seem to have Dual Core processors with 2.6GHz+ ratings, but wonder if such would be suited to my needs. Apart from lack of space for expansion, which I do not see as a problem, I have noriced that the memory speeds seem slower that on normal sized desktops.
Would anyone care to comment further on the merits of machines of either form factor for the uses I have given?
Re: Slim Desktop PCs
They often have on-board graphics which tend to be slower so could be a problem if you are editing large pictures or decide to move into video editing. Overheating can also be a problem if you are pushing the processor and they tend to have a limited PSU so adding a fast graphics card could be a problem.
They do tend to be a lot more expensive than a normal desktop / tower PC so its a trade off between performance and space.
Fixes: 12
They're considerably more difficult to upgrade too. I'm not saying impossible but harder as they don't all use pci boards etc.
VileReynard
All Star
Fixes: 11
Check that your favourite video editor can actually use 2 processors simultaneously.
Make sure you have quite a lot of memory.
Especially for Vista, Windows 7.
Luzern
All Star
Quote from: Taxisofevil
....video editor can actually use 2 processors simultaneously.
.... have quite a lot of memory.
So s/ware has to be able to use 2 processors to give full effectiveness! Do their sites actaully tell you, and do you mean video to take in photo slide-shows as well as matter shot with a video camera?
How do you define a lot of memory, presumably RAM, in the context of my usage?
Luzern
All Star
Please! Any chance of a reply from anyone?Wink
VileReynard
All Star
Fixes: 11
OK!
Why get a dual processor PC if you only use one processor?
You might be better off spending the money on a super-fast processor Smiley
Memory usage depends on the OS, the application and what kind of photo processing you do - not to mention file formats etc.
For example if you want to use many layers on a giant RAW format, it can get kind of slow. Grin
You might be better of with an ordinary desktop.
Luzern
All Star
Thx! Smiley
