Skype problem (Cannot stay connected)
deadman2020
I can't seem to connect to Skype. Or at least it is sporadic. I had thought it was to do with my blocking of Win10 telemetry using Spybot anti-beacon. But after unblocking s.gateway.messenger.live.com I still have issues connecting. I at least now get a connection but it's very sporadic and will disconnect and get stuck on an endless 'connecting' loop. I have tried disabling all of Spybot's blocking but still get the same issue. Tracert shows s.gateway.messenger.live.com redirecting to a number of different gateways (co4-s.gateway.messenger.live.com, db5-s.gateway.messenger.live.com etc). They all lag severely though.
Tracing route to db5.skype.msnmessenger.msn.com.akadns.net [40.77.226.192]
over a maximum of 30 hops:
1 * * * Request timed out.
2 * * * Request timed out.
3 6 ms 6 ms 6 ms be3-3102.pcn-ir02.plus.net [195.166.143.132]
4 6 ms 6 ms 6 ms 195.99.125.144
5 6 ms 6 ms 6 ms 62.172.103.49
6 7 ms 6 ms 7 ms 195.99.126.38
7 19 ms 18 ms 18 ms be-71-0.ibr02.lts.ntwk.msn.net [104.44.9.152]
8 18 ms 18 ms 18 ms be-3-0.ibr02.dub30.ntwk.msn.net [104.44.5.4]
9 * * * Request timed out.
10 17 ms 16 ms 17 ms ae12-0.db3-96c-2a.ntwk.msn.net [204.152.141.89]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
I have tried forwarding ports. Editing Skype's config.xml home server entry. Checked I'm not blocking anything with my firewall etc. Any ideas?
