Skype phone and speakers
- Skype phone and speakers
08-09-2011 8:16 PM
I have told SWHTBO that she can't have the speakers working because the phone is connected! Am I correct
Can the computer soundcard work at the same time as the Skypephone. I run XP on this computer
To be is to do - Kant
do be do be do - Sinatra
Re: Skype phone and speakers
08-09-2011 8:25 PM
08-09-2011 8:34 PM
08-09-2011 8:35 PM
08-09-2011 8:55 PM
Now Skype being Skype change their software functionality as it has been upgraded and I have no idea how to configure what I am asking below. There seems to be just options for the vanilla config as you describe headset and microphone
Its working that is not the problem, no I am asking to see if anyone has specific advice on USB phones
08-09-2011 9:06 PM
08-09-2011 9:26 PM
I dont recognise the options they say I should have on that forum
09-09-2011 8:12 AM
09-09-2011 3:41 PM
I used the general principles you suggested and somehow I now both my soundcard and Skype phone both Working and at the same time! A result
I have a bad attitude towards Skype and their upgrades they IMHO change the menus on their software too often. When you upgrade you cant find the options you used to have.
anyway in Skype I found the options under tools to set up the mike and speakers both to "Linksys" under drop down menues. But there was also a button for advanced options to set the priority where liynksys and the soundcard appear again!
I also went into control panel under "sound and audio devices" and here the soundcard was again set as audio device with Linksys as the mIke. I think I am lucky that there were no confilcts!
Anyway I am typing this to a background of the Black Eyed Peas
09-09-2011 8:11 PM
I have uninstalled the latest version and reinstalled an earlier version, I also disabled the auto updates.
