Skype on Linux Mint
- Re: Skype on Linux Mint
Skype on Linux Mint
18-11-2009 9:04 PM
Also, anyone else find the documentation a bit dire? I was trying to find out what my visibility was to the outside world. Skype's website says it is very easy to change the settings, but doesn't give a single word of instruction. I think I have found what I need by randomly clicking around in the application, but still...
18-11-2009 11:59 PM
19-11-2009 8:14 AM
Quote When I do a search to add her as a contact it doesn't find anything. I have tried everything I can think of - her real name, Skype name, all the email addresses I know, and nothing comes up.
That sounds about right for the Skype contact search it never seems to work as you would expect. It usually works with a Skype name though...
Sykpe works fine on Linux , I use it with Ubuntu, and since Mint is based on that, it shoudl work fine.
19-11-2009 1:04 PM
Quote from: artificer email your friend and ask her to send her skype nickname.
Nickname? Is that the same as the Skype name i.e. login name? If so, I have already tried that.
19-11-2009 1:17 PM
19-11-2009 3:37 PM
26-11-2009 9:44 PM
27-11-2009 9:12 AM
27-11-2009 1:08 PM
10-12-2009 1:03 PM
