Skygo on ipad
- Re: Skygo on ipad
Skygo on ipad
10-05-2014 9:23 AM
Sorry i know that there are a lot of topics already. However, I've tried the suggestions on those topics, but its still not working.
Any suggestions please?
I have disconnected (as in logged off the wifi and gone back on again) turned the router off etc etc, but still not working.
It says a concurrency issue.
thanks in advance
thanks in advance
4 REPLIES 4
Re: Skygo on ipad
10-05-2014 10:26 AM
If you go here http://www.whatismyip.com/ what is your IP address (you can leave the last three digits out)?
Re: Skygo on ipad
10-05-2014 10:32 AM
It's another of those problematic 146.200 IPs.
Re: Skygo on ipad
10-05-2014 10:38 AM
hi, thank you for your replies.
ip is 146.200.67
ip is 146.200.67
Re: Skygo on ipad
10-05-2014 10:51 AM
If you disconnect/reconnect from your router admin page, you should get assigned a new IP outside of the problematic range - at least that's what I was led to believe.
