Sky anytime + wireless connection
- Sky anytime + wireless connection
- « Previous
- 1
- 2
- Next »
Re: Sky anytime + wireless connection
03-09-2012 3:33 PM
Yes it does.
03-09-2012 5:09 PM
Quote It appears that the tp link is not working correctly.
That would appear to be the most likely conclusion.
One last thing to try would be to use the Diagnostic tools on the Tp link ( page 55 ) to see if IT thinks its connected to the DG834g.
Try ping to 192.168.0.1 (the DG834g ) and if that works try a traceroute to bbc.co.uk.
- « Previous
- 1
- 2
- Next »
