Sky/Netgear DG834GT Router
pd
Hi
Does anyone know if the Sky/Netgear DG834GT routers are locked to Sky?
If so, are they un-lockable?
Peter
Fixes: 247
Re: Sky/Netgear DG834GT Router
Yes they are locked to Sky and I believe you can un-lock them with a firmware flash - but as usual at your own risk
Have a look at http://www.skyuser.co.uk/forum/technical-discussion/1199-ive-done-flashed-router-got-my-sky-password...
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Very unlockable indeed!
Google should get you lots of advice on how to do it.
FYI I'm on Be not PN these days and the DG834GT is a favourite for Be's ADSL2+ connections as the chip sets match the Be DSLAM's. Indeed I use one myself (not ex-Sky, but bought long ago and used with PN). Loads of Be users buy cheap ex-Sky routers and re-flash the firmware.  Grin
pd
Cheers adiewoo & HPsauce.  I'll have a search on ebay.
Peter
£20 is the going rate + £5 delivery.
Why do you want one?
pd
I need the wireless facility which my current router doesn't have.  I do also have a Speedtouch 585v6 but no matter what I do I cannot get it to forward ports properly.  I thought I might have more luck with the Netgear.  From what I've read it seems these are two of the better routers.
Peter
holdtight
Quote from: HPsauce
Indeed i concur its very easy ive done two without any issue but as stated "at your own risk"
