Simple way to raise a ticket ?
- Simple way to raise a ticket ?
12-12-2015 10:07 AM
I have had lots of intermittent issues recently and the last one was this mysterious 'your new broadband order has a problem' messages that have appeared over the last 2 days.
I am glad to say that the intermittent issues have now been resolved so I have manually closed the ticket.
I can't find a sensible way of just opening a query on the current support pages, there are lots of 'FAQ's' which are not relevant to the query. Any links to the various options leads to an option to chat live, which I find is usually not available or to phone.
What I want to do is to open a question, provide all the details and go from there. Is this possible any more ?
Thanks.
Re: Simple way to raise a ticket ?
12-12-2015 10:12 AM
12-12-2015 10:18 AM
The most recent ones were
Intermittent line problems, now resolved.
Some unknown messages telling me that a broadband order that I had never initiated had a problem.
First one is sorted but the second one, hopefully just an internal mix-up, I had to phone up and hang about while I have a lot of work to get on with. ( My phone is not in the same room as the pc and my mobile signal in the house is practically non existent)
It would have been a simple matter, as in the past, to log a fault and provide as much relevant details as possible.
12-12-2015 10:24 AM
Try Chat
This is what you can raise a ticket about https://portal.plus.net/wizard/index.html
12-12-2015 10:58 AM
12-12-2015 11:01 AM
12-12-2015 11:03 AM
Useful Links
View your questions>http:// View your questions
Check your open and closed questions
https://portal.plus.net/wizard/?p=search
12-12-2015 11:16 AM
As I state above, mobile signal is almost non existent at my pc location and the land line phone is in a different part of the house.
The issue is for me that I work from home and I want to report a problem by email or online or whatever then get on with my work not sat waiting for the phone to be answered and remote from the pc.
That said, every time I have spoken to someone they have always been helpful but this is not my query.
As Oldjim has explained, it seems to be not possible to raise a ticket as before which I find to be a shame and an inconvenience.
12-12-2015 11:25 AM
I tend to turn off as much tracking / flash rubbish and the like for security and sanity.
Having a page hijacked by dozens of flashing / blinking ads, pop up auto playing videos etc is not only irritating but in my opinion probably a security risk as well seeing all the reported attacks on repsected legitimate websites.
12-12-2015 12:50 PM
