Silent desktop
- Silent desktop
Silent desktop
28-11-2010 11:48 AM
Re: Silent desktop
28-11-2010 11:55 AM
Re: Silent desktop
28-11-2010 12:22 PM
Re: Silent desktop
28-11-2010 12:25 PM
The speakers in the LCD screen won't work unless the audio connector on it is connected to the PC
Re: Silent desktop
28-11-2010 12:50 PM
Re: Silent desktop
28-11-2010 1:04 PM
http://www.ehow.com/how_5122046_enable-sound-windows-xp.html
or possibly this
http://www.ehow.com/how_6418579_fix-audio-driver-windows-xp.html
NOTE THE TIPS on the LEFT side Menu
Re: Silent desktop
28-11-2010 1:08 PM
Re: Silent desktop
28-11-2010 1:25 PM
Forum Moderator and Customer
Re: Silent desktop
28-11-2010 1:55 PM
Re: Silent desktop
28-11-2010 2:00 PM
Re: Silent desktop
28-11-2010 2:05 PM
Maybe a red herring, but I wanted to see what Ubuntu looked like so I tried it from the disc I downloaded, and got a whole lot of other problems I won't go into here, but it was totally silent too. Now, I don't know whether Ubuntu makes any noises under normal circumstances, but my pc did not utter a sound.
Re: Silent desktop
28-11-2010 2:10 PM
The audio connection points on the back of your monitor
Re: Silent desktop
28-11-2010 2:34 PM
Re: Silent desktop
28-11-2010 2:40 PM
Although the DVI cable is capable of feeding audio it is extremely unlikely that your video card (or on board video) will have that capability.
If you can advise the model of TFT screen and the computer I will probably be able to be more specific
Re: Silent desktop
28-11-2010 2:45 PM
