Silence following procedure
kilburncat
Yesterday I replaced the SDRAM cards on my Windows XP  desktop to 1 Gb total, and after going haywire and several restarts it is now much quicker, but I have lost the sound. The settings appear OK, I'm wondering if anyone knows what might be the cause. I can hear no windows dafault or video noises etc
5 REPLIES 5
shutter
Fixes: 65
Re: Silence following procedure
Presumably, you have checked your speaker icon is NOT muted ! ?  Roll_eyes
kilburncat
I don't have a speaker icon in the system tray but I went to Sounds in the Control Panel and Mute is unchecked.
Oldjim
Resting Legend
Fixes: 63
You aren't going to like this - did you perhaps dislodge the wire to the speaker connection
kilburncat
You are right: I was hoping someone was not going to suggest that. I will take a look tomorrow.
kilburncat
Well I've taken a look, swopped the audio plug around (to a plug that looks exactly the same to me) and the sound is back on. Thank you.
