Signing in to ASDA Direct
stathe
I have an Asda Direct account and am unable to access this on this my main Windows XP computer with free AVG security, I have no problem getting in with my Windows 7 Laptop with The Windows security it came with The router is the same for both,any ideas how I can overcome this  Thanks    Stathe
Fixes: 62
Re: Signing in to ASDA Direct
Try disabling AVG and see if this fixes it
stathe
Did the trick Thank You Old Jim I,m old but not as bright as you
Fixes: 62
Now to get a decent anti virus - I normally suggest Avira but you could use MSE as on the laptop
Fixes: 25
AVG used to be good but it has lost its way in the last few years and become too demanding to run well on older/less-powerful computers.
stathe
Does Avira check e mail?? in the free one ?Huh
Fixes: 62
I don't think so
stathe
So what makes it better than AVG which checks mail
Fixes: 62
The detection rate - trawl through the reports here which is one of the more respected sites http://www.av-comparatives.org/en/comparativesreviews/detection-test
