Show images auto on Outlook?
- Show images auto on Outlook?
29-01-2010 7:12 AM
I havnt used Outlook until today. I set up my Hotmail accounts on to it, but everytime I click on an email the images do not load. I have to right click and press download images. Is there a way to do this automatically?
4 REPLIES 4
Re: Show images auto on Outlook?
29-01-2010 8:06 AM
On the Tools menu, click Options, and then click the Security tab.
Under Download Pictures, click Change Automatic Download Settings.
Clear the Don't download pictures or other content automatically in HTML e-mail check box.
Click OK twice.
It's a security feature of Outlook to prevent you from confirming a live email address by downloading content.
Click OK twice.
29-01-2010 8:10 AM
If you are using Outlook 2007 go to Tools > Trust Centre > Automatic download and either uncheck the Dont download box or choose the options you want. There is a strong school of thought that says you shouldn't downoad automatically because of the dangers of "nasties " in the image: your call.
In Outlook 2003 the corresponding process is in Tools > Options > Security > Download options.
Good luck.
Good luck.
29-01-2010 1:32 PM
Thanks for the help. Working now.
18-06-2018 4:25 PM
Does this still work? Mine doesn’t. I have just got a new computer windows 7 before Microsoft forces everyone to get Windows 10 and now the pictures in emails are blanked out. Got a new office 2007 at the same time. I retired before the first email was sent, hence my choice of name.
