Shortcut not working ! (It is now ! ! ) NEW PROBLEM !
- Shortcut not working ! (It is now ! ! ) NEW PRO...
- « Previous
- 1
- 2
- Next »
Re: Shortcut not working ! (It is now ! ! ) NEW PROBLEM !
09-08-2011 10:21 AM
Quote from: Hairy As to it not showing in the open with the reason is you didn't INSTALL it you copied it. Try installing it or opening it and choosing the associate with function.
I did try installing it, no file type associations were created, using "Open With" then other application doesn't work either. To create something that worked I had to start from wine-extension-jpe.desktop.
09-08-2011 10:36 AM
What wine version are you using?
Also look at this thread (https://community.plus.net/forum/index.php/topic,86619.0.html) where we dealt with a LOT of infraview issues for Shutter.
09-08-2011 11:08 AM
Thanks to ejs, who has been very patient with me, and my "mess ups" I have finally got it working correctly....
09-08-2011 5:16 PM
AND...... I have just got a further 6 programs (downloaded from the net) to load and work in less than 30 minutes ! AMAZING ! ! !...
Things are looking good....!
- « Previous
- 1
- 2
- Next »
