Setting up secure wireless.
- Setting up secure wireless.
29-10-2009 8:05 PM
Hi all.
Can anyone give me some much needed guidance? Will be muchly appreciated.
My home router is a D-Link DSL-G624T and I'd like to set up a secure WiFi AP so I can use my Nokia N95-2 for downloading apps for that.
Which is the most secure setting to use WEP, WPA or 802.1x?
I've had a look at portforward.com and tried to set up a WEP connection but for some reason it won't accept the passphrase, even though it's 26 characters long.
Any ideas?
Thanks.
Any ideas?
Thanks.
3 REPLIES 3
Re: Setting up secure wireless.
29-10-2009 8:12 PM
wpa but wpa2 is better. as allways with passwords best not to use a dictionary word
29-10-2009 8:15 PM
Have a read of this library article http://community.plus.net/library/networking/7-steps-to-securing-your-wireless-home-network/
30-10-2009 4:25 PM
Thanks for the replies and links chaps
Although I seem to be struggling with one or two bits. I'm trying to go down the WPA2 route but I'm getting lost with some of the text input fields. I can see that something has to go in them but if I knew why and a few examples of what, things would be a bit easier.
(Bare with me as I'm a bit out of sorts with things, been a bit of a bad year).
