Setting up email on a BlackBerry
Midnight_Caller
Hi all
Any one know how to set up email on a BlackBerry?  I want to use my F9 email account on my BlackBerry, my network provider for the BlackBerry is Virgin Media.
[Edit]
So the email would by something@dhea.org.uk
Re: Setting up email on a BlackBerry
All email configuration is done web-side through the Virgin branded blackberry portal:  https://bis.na.blackberry.com/html?brand=virginmobile
You'll need to have the F9 IMAP details handy.
Cheers
B.
Midnight_Caller
@Barry Zubel, thank you for your help, I ended up phoning Virgin Media on: 789 and opshon 0 the opshon 1 and told to go to: http://virginmedia.blackberry.com and on ther I put in my BlackBerry PIN and my BlackBerry IMEI, then put in a User name & Password, then added my email with User name and Password plus email Server name: imap.force9.net
It is working fine.
P.S.
Do you have a BlackBerry?
