Setting up Asus RT-N66u as VPN Server
shure
I'm trying to set up my Asus RT-N66u as a VPN server.  The instructions seem straightforward enough, but I can't get the client to connect.
I have installed OpenVPN on the client.  I have generated an OpenVPN config file and placed this in the OpenVPN config folder.  So far so straightforward.  I have not changed any settings in the Advanced tab.  However, when I try to establish a connection it starts off with a couple of UDPv4 link local messages and then I get the following message:
[UNDEF] Inactivity timeout (--ping-restart), restarting
rinse, repeat.
Have I missed a step?
