Setting Up ADSL/Router
mypyrex
I am trying to install a wireless router(BT Voyager2110) I've done all the cable connections and put the installation disc in. When I go through the procedure to set up the connection with broadband(having put in my plusnet username/password) I get a message saying that the IP authentication has failed. I've double checked my username and password.
Pendragon
Re: Setting Up ADSL/Router
Just a check but are you just typing in your 'username' or are you using the full format of 'username@f9.co.uk' (in my case). You should use the full format in your router.
Regards, P.
mypyrex
Thanks for that. Have now used the full user name. I've now got internet. Smiley
Pendragon
Well done  Grin it's an easy mistake to make (and yes I did it myself  Roll eyes).
Regards, P.
puddy
if it makes you fell better i made that mistake to Grin
puddy
VileReynard
Seasoned Pro
Fixes: 9
I didn't  Grin Grin Grin
