Set up Thunderbird on Ubuntu 9.10
- Set up Thunderbird on Ubuntu 9.10
Re: Set up Thunderbird on Ubuntu 9.10
05-02-2010 4:07 PM
fobbed off with anything else.
I have tried Draw and Scribus but not Inkscape. I am afraid I didn't care for either but then perhaps I should have tried a bit harder!
Oh and yes, Shutter, Mint is prettier and more elegant than Ubuntu and very highly thought of by its adherents.
05-02-2010 4:18 PM
Hey Biker.... you say I`m "stuck in the past"............ when did DOS start? isn`t that what your using to do things "THE HARD WAY"! cmd instructions to the computer ! ! ! !
05-02-2010 4:23 PM
Hey I didn't say "I STILL USE DOS"! I have moved on, and find the terminal easier/quicker than opening a GUI to do the same thing. Having Avant on the bottom of the screen with the terminal app I can move the mouse to the bottom of the screen and type in the command and have it complete before the GUI has opened
So does Pub 98 still work in
05-02-2010 4:28 PM
05-02-2010 4:38 PM
"It's Aye Been" - Meaning Why change?
05-02-2010 5:48 PM
I`m not using W7.... I`m using Vista.... which I have no problems with ANY of my MS progs, including Pub 98.... (I do have some other progs even older in origin than Pub 98 ! )
I`m only interested in Linux (which is almost a Dos version like W3.1) so that I can acces my files and folders..... anything else Linux does is just a bonus really...
It did warn me my last HDD was "almost failed" so I bought a new one just in time. and it helped me to get the files and folders transferred from that hdd to the new one.... so "it has it`s uses".!
05-02-2010 7:11 PM
Quote `m only interested in Linux (which is almost a Dos version like W3.1) so that I can acces my files and folders..... anything else Linux does is just a bonus really...
I must say that I was a bit sceptical when I started to look at Ubuntu about a year or so ago. I had an old pc with 256mb memory and a 400mhz Celeron processor that couldn't even run w2k. So I gave it a go with Ubuntu 8.04 and was surprised how well it ran. I liked what I saw and so got a new motherboard, dual core Athlon64, 1Gb memory and a half decent SATA drive and upgraded the box a bit!. This is now my main PC. For general purpose work, browsing, email, simple document manipulation, VPN to the office, VNC for remote access etc, It works great, takes about a minute to boot up to the desktop, what more can you want. TBH I very rarely use my Windows box anymore. I got an Acer Aspire One netbook a while ago and immediately put 9.04 on that, its great for taking around with me, nice and light, does everything you need on the move and even works with my mobile broadband dongle!!
08-02-2010 11:18 AM
09-02-2010 11:09 AM
09-02-2010 11:20 AM
09-02-2010 11:23 AM
1. Right-Click on My Computer and select properties
– (In Vista you can select View System Information from the Computer window.)
2. From the System Properties window select the Advanced tab
3. Push the Settings button under Startup and Recovery
4. Select the default OS from the Default operating system dropdown box.
5. Click OK twice.
09-02-2010 11:51 AM
PS Linux mint is based on Ubuntu so the instructions should be ok
09-02-2010 11:59 AM
shows Start up and Recovery and then Settings button
System startup
Default operating system: and in the box is Microsoft Windows Vista... there are no other options when pressing the "down arrow" for the drop down....
Just says time to display and it is set at 30 seconds..
Not sure if it can be done, because the "boot choice" window is produced by the Linux Mint 8, not MS Vista (i.e. black screen with white lettering as would be if running XP and Vista... )
probably have to do it some really "geeky" way by rewriting the boot sequence in the Linux Mint OS. !
Thanks for the suggestion Jim.
HA ! MisterW.... you have hit the nail on the head.....! cheers for the suggestion !
Edit...... I may turn into a geek sometime soon ! ! ! .....
15-02-2010 11:09 AM
It's not possible to select and drag/drop emails into a folder as it is with WM and Windows Live Mail.
Have not used TB3 and wondered if this problem has been addressed in this new version?
15-02-2010 11:26 AM
