Sending emails using Mozilla Thunderbird
davidjatkin
Re: Sending emails using Mozilla Thunderbird
Thank you again MrW.  I will wait and try again tomorrow.
shutter
Fixes: 67
@MisterW  & @davidjatkin
I have the same problem,  and I think MisterW has the answer... it is because of your  i.p.
I use a 4G LTE router on a Mobile Phone Sim only monthly contract for my internet connection... ( permanent arrangement) . I can send and receive emails from my @gmail.  addresses.. but can only receive to my pn address.. cannot send from it..
If you are going away regularly, it may be an idea to set up an alternative @gmail address  to send and receive emails  on "forren" internet connections.
Fixes: 579
The problem is that most mobile networks use CGNAT, this means that the 'real' public IP is shared between many users. It only takes one bad player and the shared IP gets a poor reputation.
I used to go to Portugal in the winter for a few weeks and many of the rentals used mobile broadband. I would often hit the problem of not being able to send for a day or two. Latterly the villa we rented changed to a cable connection and the problem no longer existed.
The SMTP protocol does return an error code which identifies the cause, however most email clients don't expose it, rather they just return an error of 'failed to send' often with a username/password reason
davidjatkin
Many thanks.  Reassuring to know I am not the only one,
I will look at the gmail route.
