Sending .avi files by email: he;p please
Luzern
Seasoned Pro
I have a .avi clip that I wish to send to a relative. At 28MB it is too large for email as it stands.
Is there a way (free) to send this, so that when it is shown full screen it will be of reasonable quality? May I have to convert it to some other format to do successfully send it?
Re: Sending .avi files by email: he;p please
there are free upload sites you could use.  www.YouSendIt.com ; is one.  just google upload fileshare and you'll get lots of offers.
another way is dcc through an instant message service, such as skype, though they take a long time that way.
uploading to the spare space on gmail is also possible.
lots of possibilities.
you could probably zip it to about 15MB too
You can send it by email if the other person can receive large emails.
There are free avi file splitters out there or as suggested zip it into smaller segments and send it via several emails and then when they uzip it they will have the full file
Luzern
Seasoned Pro
Quote from: samuria
.... zip it into smaller segments and send it via several emails .....they uzip it they will have the full file
But obviously not as a continuous item.,,more like separate reels?
Fixes: 226
Why not FTP it to your free PN site and send the URL in an email?
If you're concerned about others seeing it then put it in a passworded zip file first.
Forum Moderator and Customer
If its zipped into several files it goes back as one file once unziped its not separate files
Assuming you have a static IP as I think most of us do with PN you could use a free webserver or ftp server on your computer to allow the person to download it directly from you. I regurarly do this with files of well over 100 Mb
pierre_pierre
web address is usually username.plusnet.co.uk/name.mpeg
or for older user like me
username.free-online.co.uk or username.idps.co.uk or username.me.uk  all get the same file
I have been with PN for several years and my webspace address is username.plus.com
pierre_pierre
could be, I am a free-online immegrant
I think I have been with PN for about 4 years and that was allways my address. I used to use the webspace but then I quickly learned that paid cPanel/WHM reseller hosting was a much better option for my websites. Not sure if there is anything on my webspace, must go check!
