Seemingly more hangs (item reposted from incorrect section)
- Re: Seemingly more hangs (item reposted from incor...
12-02-2008 1:02 PM
Computer is on XP Home
Amd Athlon 2400+ processor 80GB hard drive
512 (2*256)MB PC 2700 DDR RAM
I have very recently done a disk clean up and a defrag.
Suggestions as to probable cause and cures would be much appreciated.
Re: Seemingly more hangs (item reposted from incorrect section)
12-02-2008 1:16 PM
1. Run a registry cleaner like Tweaknow http://www.download.com/TweakNow-RegCleaner-Standard/3000-2094_4-10262639.html
2. Make sure your antivirus and antispyware software is up to date and do full scans.
3. Temperature can cause this kind of thing. Open the side of your PC (with it plugged in but shut down) and check the heatsinks. They can get clogged with dust and reduce the heat dissipation.
4. Make sure XP's updates are, err, up to date.
5. Has it coincided with installing any new hardware or software? If so uninstall it and see what happens.
13-02-2008 4:40 PM
Quote from: lucerne Computer is on XP Home
Yup, theres the problem.
Pro is far more reliable. Home is like the Win9x series (unstable) where as Pro is more like the business aimed NT series which was designed to be stable (Or more to the point the Win9x range was designed to be unstable so business's would buy the expensive NT range).
If you can get XP Pro somehow, I think you'll find your problems disappear. I used to use WinME and while it was better than Win98SE it used to crash quite easily. Upgraded to XP Pro and don't really have many problems now.
13-02-2008 4:48 PM
Sure some of the tools and options are missing, but I've certainley not experienced any problems with instability on XP Home (if I had, I'd have installed XP Pro for at home as well)
13-02-2008 4:58 PM
I know what you're saying but sometimes the OS likes or dislikes different hardware for unknown reasons.
I used Win98SE and it was the worst OS I've ever used. It wouldn't stay stable for longer than 40 minutes. A lot of other people I know say it's the best they've had and it never crashes.
I preferred WinME while those same people said it was junk.
My point is, while it may work well for some users, frequently it works not so well for others. I was one of those others. I dumped the 9x series and moved on to XP Pro. No trouble ever since. I get the occassional hardware glitch sometimes but very few crashes or software errors.
14-02-2008 1:18 PM
20-02-2008 9:59 AM
Quote from: Denzil Things to try, if you haven't already:
Just waiting for new RAM to come, which incidentally I;d ordered before the problems. Will deal with 3 then. BTW what do most sensible folk use to do the cleaning?
20-02-2008 10:05 AM
20-02-2008 11:44 AM
I can't agree with the XP home theory I have run both with no difference in reliability and as PJ said it is the same code with some sections dropped, mostly through registry changes and selective install routines.
11-03-2008 11:03 PM
11-03-2008 11:04 PM
B.
