Security scan
Fixes: 9
Security scan
Have just done a Norton free security scan and on one section get the message some areas were vulnerable as Microsoft Internet Explorer 5.00 was not up to date.
I Never use Microsoft internet explorer as Firefox serves my needs so is there any way I can either switch off or block explorer so it's not vulnerable to threats ?
pierre_pierre
Re: Security scan
there will be shortly, one of the M$ updates is their attempt to get out of the EU decree and let you choice your own browser, it was on last Tuesdays updates
Fixes: 62
Re: Security scan
It isn't vulnerable if you never use it
If you never use it why not upgrade to IE8 and don't use that  Grin
VileReynard
All Star
Fixes: 11
Re: Security scan
M$ have a nasty habit of using IE to display web pages.
If it isn't there, it can't do that.
Fixes: 62
Re: Security scan
Only problem - given that the OP is using XP at the latest Internet Explorer is totally non removable.
I am not sure it is in anything earlier than Windows 7 either (it is reputed to be removable in Windows 7 but I haven't seen evidence of it).
Steve
Seasoned Pro
Re: Security scan
I dont think it is removable in windows 7 oldjim, you can close it down but thats about it,well thats what ive discovered.
If life gives you lemons, make lemonade.
pierre_pierre
Re: Security scan
what about those stupid companies who check which browser you are using and if it isnt M$ wont load, still seeing them, a Local Government one recently
