Security Warning
jennyBA
Security Warning
Hi, can anyone help with this please. We got this warning come up on screen and don't know what it means, is it important and if so how do i fix it.
I took photo of the screen if you enlarge image you can just read it and get the idea what its on about
12 REPLIES 12
VileReynard
Fixes: 20
Re: Security Warning
This looks like a generalised message - who sent it to you and why?
If you have a Plusnet supplied router, the degree of configuration is so poor that you probably couldn't switch the remote configuration (via the admin pages) option on.
On other routers, there is often an option to be able to remotely administer your router - but no-one(?) would switch this on unless there was some vitally important feature that made it necessary.
You can test this by trying to login to your router via the internet-facing address (the WAN address).
Alternatively you could run a port scan test to see what services your router is reporting as being potentially accessible from the internet.
I tend to use GRC ShieldsUP! to check my system.
Go to the GRC website - https://www.grc.com/
Select "ShieldsUP!" from the drop down [Services] tab.
Click on the [Proceed] button
Click on the [All Service Ports] button (near the centre of the page)
Let the test run for about 70 seconds
Then read what the recommendations are if you don't get a perfect result like this -
jennyBA
Thank you, i have run the test following your advice and it all came out green and said passed, so i don't think i have anything to worry about.
jennyBA
It was flashed up on screen by Avast Security software that we have installed.
VileReynard
Fixes: 20
It's was just a generic warning about routers in general - it listed just about all the different brands of router!
It knows nothing about your particular router, so it can be safely ignored.
bobpullen
Fixes: 316
That GRC scan is not conclusive. There are thousands of available ports it hasn't scanned.
VileReynard
Fixes: 20
You can't prove that some ports aren't left open by doing occasional port scans, anyway.
Just an indication that there is nothing obviously wrong.
@jennyBA  if that message occurs again, try logging in to your router's configuration pages, find the settings for "UPnP" and try setting that to being disabled.
On routers where UPnP is enabled, it is possible that a device anywhere on your home network has silently asked your router to provide a backdoor through your router's security firewall so that some remote computer on the internet can access something on your otherwise protected home network (which if malicious could present a security risk) - this might have been what triggered the warning screen that you saw.
In practice UPnP is rarely needed these days, and disabling it shouldn't cause any problems.
@bobpullen
While that is technically true, the warning on @jennyBA's screen shows -
"The admin interface of your router is accessible from the internet"
Assuming the router is a standard Plusnet router, what are the default port numbers used by the WAN facing admin interface ?
My guess would be TCP port 80 is the default, and would therefore have been covered by the GRC test suggested.
If there are other ports used, then it would be simple to go back and test those with the GRC port scanning tool.
VileReynard
Fixes: 20
The WAN port 80 is not open, as shown by that GRC scan.
It's likely that port 80 is open on the LAN side - to access the configuration screen, but that doesn't matter, especially since its password protected.
bobpullen
Fixes: 316
@Anonymous wrote:
@bobpullen
It's a Hub Zero, and I don't believe it offers a native option of opening up the admin interface to the outside world.
Perhaps the warning is being triggered by the TR069 connection port (7547)?
~ $ sudo nmap -Pn -p 7547 146.198.[REDACTED]
Starting Nmap 6.47 ( http://nmap.org ) at 2019-02-09 00:40 GMT
Nmap scan report for [REDACTED].198.146.dyn.plus.net (146.198.[REDACTED])
Host is up (0.024s latency).
PORT     STATE SERVICE
7547/tcp open  unknown
Nmap done: 1 IP address (1 host up) scanned in 0.84 seconds
VileReynard
Fixes: 20
I thought I'd succeeded in turning off TR-069 (also known as CWMP) on my non-Plusnet router - butCry
~ $ sudo nmap -Pn -p 7547 51.6.89.xxx gives:-
Starting Nmap 7.40 ( https://nmap.org ) at 2019-02-09 02:08 GMT
Nmap scan report for xxx.89.6.51.dyn.plus.net (51.6.89.xxx)
Host is up (0.00068s latency).
PORT     STATE SERVICE
7547/tcp open    cwmp
Nmap done: 1 IP address (1 host up) scanned in 0.29 seconds
I shan't bother about it, since all the parameters in the boxes are blank & my previous Plusnet supplied router ran for years with the port open.
Actually, any commercial public ip address will show that some kind of firewall is blocking port 7547.
