Second Router
- Second Router
Second Router
09-09-2019 6:25 PM
Long story. The router in our house is in a really poor location for wifi. What we can do is Hardwire to another room and set up a second router.
I appreciate there are other options. I would like to give the second router a try.
What would folks recommended if buying a router?
Re: Second Router
09-09-2019 7:16 PM
Why not do the hardwire to the other room anyway.... and use the current router... it may be a better location, and if it works better... no need to buy another router..
My router is hard wired to a secondary wall socket, about 15 mtrs from the "master socket" location , and works fine... more convenient if it needs a reboot too ...
Re: Second Router
10-09-2019 11:05 AM
A router can complicate the setup, people usually use one because they have a spare lying around and not investing in a new one.
