Search in Documents doesn't appear to work in W7
- Re: Search in Documents doesn't appear to work in ...
21-11-2011 1:49 PM
Using the search box on the top right works for all folders on all drives except, it seems, the Documents (My Documents Sub) folder.
Windows 7, Home Premium, 64 Bit.
Anyone else experience this?
Forum Moderator and Customer
Re: Search in Documents doesn't appear to work in W7
21-11-2011 2:26 PM
21-11-2011 2:30 PM
My search button is set to search file names and contents
21-11-2011 2:37 PM
Strange thing is if I do a search on C: then the search does include files found in Documents (My Documents).
But even if I search in a Sub folder of Documents no search occurs.
21-11-2011 2:39 PM
21-11-2011 2:43 PM
Cheers
