Search Engine Problems
- Re: Search Engine Problems
11-10-2011 7:43 AM
plusdsl customer, sudeenly my system cant access google (web, images, vieoes etc) but can access google maps, thought the problem was Moszilla, so tried IE, cherome and opera, problem still exiests.
Then tried Yahoo and Altavista browsers and they dont appear.
Tried a laptop using same router all is ok, prolem seems to be fine.
Any idea's as to the problem. T.I.A.
11-10-2011 10:41 AM
If you open a command window and type in
tracert www.google.co.uk
you should get something like this
C:\Users\Jim>tracert www.google.co.uk
Tracing route to www.l.google.com [209.85.229.103]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 40 ms 38 ms 39 ms lo0-central3.ptn-ag01.plus.net [195.166.128.204]
3 39 ms 37 ms 36 ms gi2-18-131.ptn-gw01.plus.net [84.92.3.153]
4 37 ms 37 ms 37 ms 72.14.223.32
5 38 ms 37 ms 115 ms 66.249.94.76
6 39 ms 37 ms 38 ms 209.85.253.196
7 44 ms 44 ms 44 ms 66.249.95.173
8 44 ms 43 ms 44 ms 209.85.251.231
9 * 44 ms 52 ms 209.85.243.81
10 44 ms 43 ms 47 ms 209.85.229.103
Trace complete.
11-10-2011 2:16 PM
tried with firefox/chrome/IE and opera
Results pasted below, but still no access to browsers today.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Me>tracert www.google.co.uk
Tracing route to www.google.co.uk [64.125.87.147]
1 * * * Request timed out.
2 25 ms 28 ms 28 ms lo0-central3.pcl-ag02.plus.net [195.166.128.237]
3 25 ms 25 ms 24 ms gi1-23-231.pcl-gw01.plus.net [84.92.6.48]
4 25 ms 25 ms 25 ms po4.pcl-gw02.plus.net [212.159.1.129]
5 25 ms 25 ms 25 ms po5.thn-gw02.plus.net [212.159.1.133]
6 35 ms 25 ms 25 ms 1-2.r1.lo.hwng.net [195.66.224.227]
7 101 ms 99 ms 100 ms 4-1.r1.ny.hwng.net [69.16.190.209]
8 98 ms 111 ms 99 ms 209.197.17.198
9 106 ms 106 ms 106 ms edge.hnlv.net [69.10.52.74]
10 105 ms 105 ms 109 ms 64.125.87.147.available.above.net [64.125.87.147
Trace complete.
11-10-2011 4:26 PM
There are a number of possibilities but two to check are whether you have any malware - try doing a full scan with http://www.malwarebytes.org/
Next see what is in your hosts file http://support.microsoft.com/kb/972034
Another couple of things to check
If you type
ipconfig /all
in a command window (not the space between ipconfog and /all)
what are the DNS servers shown as
Can you check what the router shows for the DNS servers
12-10-2011 1:27 AM
Just doing the full scan as we speak.
Not sure I understand the Host reset bit.
C:\Documents and Settings\Me>ipconfig all
Error: unrecongnized or incomplete command line.
USAGE:
ipconfig [/? | /all | /renew [adapter] | /release [adapter] |
/flushdns | /displaydns | /registerdns |
/showclassid adapter |
/setclassid adapter [classid] ]
where
adapter Connection name
(wildcard characters * and ? allowed, see examples)
Options:
/? Display this help message
/all Display full configuration information.
/release Release the IP address for the specified adapter.
/renew Renew the IP address for the specified adapter.
/flushdns Purges the DNS Resolver cache.
/registerdns Refreshes all DHCP leases and re-registers DNS names
/displaydns Display the contents of the DNS Resolver Cache.
/showclassid Displays all the dhcp class IDs allowed for adapter.
/setclassid Modifies the dhcp class id.
The default is to display only the IP address, subnet mask and
default gateway for each adapter bound to TCP/IP.
For Release and Renew, if no adapter name is specified, then the IP address
leases for all adapters bound to TCP/IP will be released or renewed.
For Setclassid, if no ClassId is specified, then the ClassId is removed.
Examples:
> ipconfig ... Show information.
> ipconfig /all ... Show detailed information
> ipconfig /renew ... renew all adapters
> ipconfig /renew EL* ... renew any connection that has its
name starting with EL
> ipconfig /release *Con* ... release all matching connections,
eg. "Local Area Connection 1" or
"Local Area Connection 2"
C:\Documents and Settings\Me>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . :******** (Blanked by me)
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Marvell Yukon 88E8056 PCI-E Gigabit
Ethernet Controller
Physical Address. . . . . . . . . : 00-23-54-07-8C-B7
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Marvell Yukon 88E8001/8003/8010 PCI
Gigabit Ethernet Controller
Physical Address. . . . . . . . . : 00-23-54-07-94-F9
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : 11 October 2011 22:03:59
Lease Expires . . . . . . . . . . : 11 October 2011 23:03:59
C:\Documents and Settings\>
12-10-2011 9:52 AM
Quote from: wappydoodle Microsoft Windows XP [Version 5.1.2600]
You missed the /
ipconfig /all
Ex-Broadband Service Manager
12-10-2011 9:58 AM
Instructions: http://www.plus.net/support/software/dns/changing_dns_xp.shtml
12-10-2011 3:56 PM
12-10-2011 6:13 PM
12-10-2011 10:18 PM
