Seagate External 2TB HDD via USB unknown
nickhsw19
Recently got a new hub from plusnet - one problem is that our HDD wont work with it - pic of mode attached.
The drive worked ok in a TP Link router and is also functioning in windows kit.
Anyone managed to get one to work?
5 REPLIES 5
wisty
Fixes: 8
Re: Seagate External 2TB HDD via USB unknown
Check the file system it is formatted as, and the block allocation size.
I don't know what file systems the HH5 supports, the specs should be out there somewhere.
Browni
Aspiring Hero
Fixes: 60
Supported formats are FAT16, FAT32 & NTFS.
VileReynard
Fixes: 20
Is the disk formatted  as a GPT or MBR type?
Can the HH5 handle UEFI style disks?
nickhsw19
The filesystem type is NTFS - but it looks like the hub doesnt recognise it.
The HDD works in other environments so I guess its some feature of the hub
VileReynard
Fixes: 20
Aren't there different flavours of NTFS?
e.g. Win 7, XP, Win 10, NT4 etc
