Seagate External 2TB HDD via USB unknown
- Seagate External 2TB HDD via USB unknown
24-04-2017 5:31 PM
Recently got a new hub from plusnet - one problem is that our HDD wont work with it - pic of mode attached.
The drive worked ok in a TP Link router and is also functioning in windows kit.
Anyone managed to get one to work?
Re: Seagate External 2TB HDD via USB unknown
24-04-2017 11:21 PM
Check the file system it is formatted as, and the block allocation size.
I don't know what file systems the HH5 supports, the specs should be out there somewhere.
24-04-2017 11:39 PM
25-04-2017 2:27 AM
Is the disk formatted as a GPT or MBR type?
Can the HH5 handle UEFI style disks?
25-04-2017 12:46 PM
The filesystem type is NTFS - but it looks like the hub doesnt recognise it.
The HDD works in other environments so I guess its some feature of the hub
25-04-2017 1:03 PM
Aren't there different flavours of NTFS?
e.g. Win 7, XP, Win 10, NT4 etc
