Screen and sound capture
VileReynard
Seasoned Pro
Fixes: 10
I'm not sure i want to be asking this question Cheesy
I'd like to capture, ideally as a video file, anything that appears on my screen - including audio.
I seem to have a very limited sound card.
I can easily capture video - using xvidcap - but no sound.
I'd settle for separate audio, though.
My motherboards soundcard is a CK804 (I think).
I think I'm using ALSA - but I don't understand Linux audio. Grin
Fixes: 20
Re: Screen and sound capture
Well first obvious q is what distro and release are you running?
Audcaity will capture the audio in a loopback form if your card allows full duplex, if not then you need to feed the headphone->input manually.
VileReynard
Seasoned Pro
Fixes: 10
Thanks for the help...
Well Ubuntu 9.10 - and I have Audacity - but I think I would have to feed the output back into the microphone(?) input.
Since the recording would only be a secondary backup and the double D-A plus A-D conversion by a cheap soundcard will sound very rubbish, I think I will give up!
Fixes: 20
Well the first thing to try is to play something in rythmbox (e.g. an mp3) and see if audacity will record it without needing a cable, i.e. full duplex.
Or try, right click on the speaker, and choose preferences. In the combo box does it show "Analog Stero Duplex" ? (mine does on both my systems) if so then audacity will record directly without a-d-d-a conversion.
VileReynard
Seasoned Pro
Fixes: 10
Quote from: Hairy
I tried an mp3 through "movie player" - sound was fine.
But audacity picked up nothing - even though the volume control shows "Analog Stero Duplex".
I wonder if its an audacity problem - it won't play an imported mp3 Cheesy
Fixes: 20
OK in audacity change where it gets it audio from, RHS of the screen at the top is a drop down that probably says Mic, try changing to Line
VileReynard
Seasoned Pro
Fixes: 10
Well - after I had changed one of preview options in preferences(?) from 3 seconds to 30 seconds , and
audacity now plays tunes - but doesn't capture. Cry
As you can see, the volume control sees audacity trying to record and totem playing.
Fixes: 20
I had to play with it to get it to capture but I manged to capture a play from spotify (via wine) so it will do it, keep playing  Cheesy
VileReynard
Seasoned Pro
Fixes: 10
Well - I'll keep trying then!
Watch this space. Cheesy
Fixes: 20
How did you get on?
VileReynard
Seasoned Pro
Fixes: 10
I gave up! Cry
I was afraid of totally screwing up the sound!
It seems that every man and his dog has a "standard" sound system!
OSS, ALSA, JACK, ESD...
Perhaps I should just connect the output to the microphone via a piece of wire... Smiley
Fixes: 20
Ok just tried on my spare machine, fresh install of Audacity:
Open Audacity and press Ctrl-P choose Recording and Pulse. Close and click on the Mic icon and choose Monitor.
Open the Pulse Audio control panel, choose Volume Control.
Choose Recording, and select the Monitor of playback device
Volia ! all done!
Easy wasn't it  Roll eyes
VileReynard
Seasoned Pro
Fixes: 10
Well, Hairy Biker....
You are an absolute star of the first magnitude!!! Smiley Smiley Smiley
I managed to follow your instructions and we (collectively) have succeeded in playing Terry Pratchett's "Guards Guards!" (mp3) via movie player via audacity back onto my hard disk.
So it works. Cheesy Cheesy Cheesy
However, [because I use Gnome(??)] I had to install some pulse audio stuff...
I seem to have pulse audio + alsa now - but everything still works Smiley
Next step is to record sound and video off of a Java based applet, which I will try later tonight.
Many thanks.
VileReynard
Seasoned Pro
Fixes: 10
Thanks once again, Biker Smiley
I have succeeded in doing an almost full screen video grab with xvidcap whilst simultaneously capturing the audio with audacity  Smiley
So all I have to do is merge the video and audio streams.
Fixes: 20
Quote from: A
Not my fault!  Smiley Ubuntu introduced Pulse as the default in 8.10 (I think) you needed to add the pulse audio applet/manager (I have it added by default so forget about it) I also use Gnome so no difference there.
