Screen Breaking Up
- Re: Screen Breaking Up
Screen Breaking Up
19-05-2014 5:07 PM
Most of last week when I have had BBC 1 on my TV I have noticed the picture is trying to break up and the sound is also a problem lines are across the screen this has nothing to do with Sky it is coming from digital arieal on the chimney stack,all the other channels are fine
4 REPLIES 4
19-05-2014 5:44 PM
You have managed to get a weak signal strength on your aerial - for BBC1 only?
19-05-2014 5:46 PM
Try a retune maybe
19-05-2014 6:35 PM
I have moved the TV set a few inches along and for 30mins or so I have had no problems weird I wonder why.
19-05-2014 6:42 PM
Dodgy connection on your aerial socket maybe?
