Scanner Speed
morgan2476
Scanner Speed
What determines the speed at which a scanner scans a document?  Is it the pc or is it the scanner itself?
Re: Scanner Speed
Both  Grin
I have a Panasonic KV-S1025C which is quite a fast scanner, but it went even faster when connected to a fast PC.
Now Zen, but a +Net residue.
morgan2476
Re: Scanner Speed
The Panasonic would be a bit expensive for me.  I am looking for a reasonably fast reasonably priced flatbed scanner.  Are there any good comparison sites?
Fixes: 62
Re: Scanner Speed
In my case it is the scanner and it just might be the usb connection speed limiting it
Re: Scanner Speed
Quote from: morgan2476
last time I went to buy a scanner I bought a printer/scanner for £60  Cheesy
What is the point of a cheap standalone scanner when all printers include one now?  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Fixes: 17
Re: Scanner Speed
In my case.  the point of having a seperate printer and scanner, is SPACE... or lack of ... to be exact..
I have a flatbed scanner, which I maybe use only once or twice a year, so it is kept "in the shed", as I only have room for a printer in my desk cupboard. no space on top, so it must be a front loading type, not "gravity feed"
thejudge
Re: Scanner Speed
Another key element in scanning speed is how high you set the scanning resolution and, naturally, the size of the item you're scanning.
Fixes: 10
Re: Scanner Speed
The Kodak scanner I was working on today scans at the rate of over 100 double sided A4 pages per minute at 300dpi. A very good scanner but I guess that might be faster than you need and a little out of your price range!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
VileReynard
Seasoned Pro
Fixes: 10
Re: Scanner Speed
I expect we can see a few hundred books on bit-torrent in the near future!  Cheesy
