Samsung SSD
- Re: Samsung SSD
Samsung SSD
22-12-2012 4:04 PM
I've seen a 256GB solid state drive for less than £150 (new retail). Seems a bargin.
Anyone have any opinions on SSD drives. I would consider using it for OS and 'program files' directory. I've several applications that are 'slow' to load.
Re: Samsung SSD
22-12-2012 4:22 PM
Amazon tend to have good prices on the Samsung 830 and 840 SSDs.
Re: Samsung SSD
22-12-2012 10:52 PM
Re: Samsung SSD
22-12-2012 11:40 PM
Re: Samsung SSD
23-12-2012 7:39 AM
http://thessdreview.com/ssd-guides/optimization-guides/the-ssd-optimization-guide-2/
Re: Samsung SSD
23-12-2012 8:55 AM
Re: Samsung SSD
23-12-2012 11:46 AM
SSDs with Sandforce controllers appear to be the most problematic when it comes to compatibility. I initially bought a Sandisk Extreme which is a nice SSD, but didn't work correctly on the system it was intended for. The Samsung 830 and Intel X25-m have worked in anything I tried them in.
Re: Samsung SSD
23-12-2012 6:32 PM
I would imagine a 64GB SSD would be ample.
Even a 256GB device is much too small for storing audio-video on, anyway.
You can still have a rotating disk for temporary or low priority stuff.
Re: Samsung SSD
23-12-2012 6:34 PM
As you say i havent Disabled recyle bin but have disabled System restore and in the past 12 months it never has been needed
Re: Samsung SSD
23-12-2012 6:59 PM
Re: Samsung SSD
11-01-2013 4:07 PM
Re: Samsung SSD
11-01-2013 5:42 PM
Re: Samsung SSD
08-02-2013 9:54 AM
Re: Samsung SSD
08-02-2013 10:15 AM
http://www.overclockers.com/forums/showthread.php?t=717026
Re: Samsung SSD
08-02-2013 11:38 AM
I keep all the 'permanent' stuff on the SSD and all the dynamic stuff on a 500gig Samsung spinner.
York.
