Samsung Genio touch and email
mikemoreton
I,ve got a Samsung Genio touch and have tried several suggestions to get my Plusnet email to work but keep getting a "failed to connect" message. Hs anyone got any ideas?
1 REPLY 1
Fixes: 395
Re: Samsung Genio touch and email
Ok, no-one else seemed to be able to help so I'll give it a try.
I've no direct experience with the Samsung but O2 have a guide for setup here http://mobilereviews.o2.co.uk/devices/device.jsp?deviceId=604&tab=8&step=2&settingId=2830 and a guide for non-o2 ISP's here http://www.o2.co.uk/ISPsettings ( just use the pull down menu to select PlusNet ).
Now they refer to using 'screen name' in the account username field. My best guess is that it would be your username and password for your PlusNet email account as you would use to login to webmail i.e 'account+user' .
Hope that helps
