Samsung 7400 tv
- Samsung 7400 tv
Samsung 7400 tv
15-02-2019 1:33 PM
Except Samsung tv think I've tried everything changing the dns to 8888, 8844, and get auto. Still i have a problem with streaming YouTube ect buffering all the time. Don't have any problem on the other tvs which are lgs.
Many thanks
Re: Samsung 7400 tv
15-02-2019 2:26 PM
Re: Samsung 7400 tv
15-02-2019 2:35 PM
Re: Samsung 7400 tv
15-02-2019 2:44 PM - edited 15-02-2019 2:46 PM
This is a 4K TV so you need 15-25Mbps download speed over wifi to stream UHD without buffering. That's without any other devices using your bandwidth. Have you tried measuring your download speed at the TV location? As @Gandalf suggests, Ethernet cabling is good. It's the only way to guarantee the best and most reliable connection speed. That's assuming of course that the VDSL service at your property is fast enough. What speed do you get using an Ethernet cable to connect to your router?
One further thought, have you tried separating the 2.4 and 5 GHz channels, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Re: Samsung 7400 tv
15-02-2019 2:52 PM
Moderators Note
This topic has been moved from Fibre Broadband to Tech Help.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
Re: Samsung 7400 tv
15-02-2019 3:45 PM
@Gmmac I have a KS8000 TV that when watching any 4K UHD TV such as Amazon's The Grand Tour it consumes in excess of 25Mbps so as has been mentioned you need to check your VDSL throughput to ensure you have the capacity.
Also, for what it is worth my TV is connected using a TP-Link PA9020 and it works perfectly well for me, so it might be worth consideration.
Re: Samsung 7400 tv
15-02-2019 3:54 PM
Re: Samsung 7400 tv
15-02-2019 3:57 PM
Have you tried separating the channels and selecting the best?
