Samsung 7400 tv
Samsung 7400 tv
Can anyone help am on fibre and have no problems with anything connected via WiFi.
Except Samsung tv think I've tried everything changing the dns to 8888, 8844, and get auto. Still i have a problem with streaming YouTube ect buffering all the time. Don't have any problem on the other tvs which are lgs.
Many thanks
7 REPLIES 7
Fixes: 866
Re: Samsung 7400 tv
Hi there.
Do you get the same issues when you plug your TV into the router using an ethernet cable (if that's possible)?
Re: Samsung 7400 tv
Not really possible i would preferred to be hard wired. I dont have a problem with my oled lg and thats 3 times further away from the router
Fixes: 118
Re: Samsung 7400 tv
This is a 4K TV so you need 15-25Mbps download speed over wifi to stream UHD without buffering. That's without any other devices using your bandwidth. Have you  tried measuring your download speed at the TV location? As @Gandalf suggests, Ethernet cabling is good. It's the only way to guarantee the best and most reliable connection speed. That's assuming of course that the VDSL service at your property is fast enough. What speed do you get using an Ethernet cable to connect to your router?
One further thought, have you tried separating the 2.4 and 5 GHz channels, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Fixes: 414
Re: Samsung 7400 tv
Moderators Note
This topic has been moved from Fibre Broadband to Tech Help.
Customer and Forum Moderator. Windows 10 Firefox 74.0 (64-bit)
Life is tough enough without adding Linux into the mix.
Re: Samsung 7400 tv
@Gmmac I have a KS8000 TV that when watching any 4K UHD TV such as Amazon's The Grand Tour it consumes in excess of 25Mbps so as has been mentioned you need to check your VDSL throughput to ensure you have the capacity.
Also, for what it is worth my TV is connected using a TP-Link PA9020 and it works perfectly well for me, so it might be worth consideration.
Re: Samsung 7400 tv
Thanks for replies am not watching 4 k on the samsung although the lg oled plays 4k without any problem. Am just steaming YouTube even my phone streams 4k without a problem
Fixes: 118
Re: Samsung 7400 tv
Have you tried separating the channels and selecting the best?
