Same IP address as another Plusnet user?
- Same IP address as another Plusnet user?
28-05-2015 5:13 PM
Re: Same IP address as another Plusnet user?
28-05-2015 5:18 PM
It's not possible for you to allocated the same address that someone else currently has but it could well be that you have been allocated the one they had at the time they were banned. It's not very clever of the forum concerned to ban by IP address, since they are dynamically assigned and over a period of time could well be allocated to a number of people.
Quote so is it possible that I might have temporarily ended up with the same IP address as someone else?
28-05-2015 5:20 PM
28-05-2015 5:49 PM
28-05-2015 6:41 PM
28-05-2015 6:53 PM
Quote from: spraxyt Have they actually banned your username or just the IP? If it's the latter then disconnecting from Plusnet using the router's GUI, then reconnecting should get you a new one which hopefully will be OK.
They banned my whole account because of the IP. Ah well.
