Sagen 2704N port forwarding issue
- Sagen 2704N port forwarding issue
01-08-2015 3:22 PM
My assigned port to a device stays open for 1 hour or so and then it cannot be accessed externally and appears closed.
Anyone else gets this issue?
The problem fixes itself by restarting the router
4 REPLIES 4
Re: Sagen 2704N port forwarding issue
01-08-2015 4:00 PM
What Equipment are you trying to open a port for ?
Can you ping the router from the device to keep the device in the arp table ?
01-08-2015 4:03 PM
It is an IP cam so cannot ping anything from that device
01-08-2015 6:51 PM
Not much hope there then
This Thread gives an idea of what may be happening, not sure if plusnet has a ticket open for this problem on not, or even if they care about it.
01-08-2015 9:10 PM
Quote from: 11110_110 Not much hope there then
Yeh sounds like my problem which I dont think wil lbe sorted unless I get my own router. I spoke to support and it is not something they can help me with apparently, even though I pay for the static IP to be used for something like this.
Joke! Thanks for your help
