Sagemcom 2704N
Eggs
Sagemcom 2704N
Just a quick question.
In Broadband Basic Settings, what is the Broadband Username and Broadband Password used for and how can I change them?
Also, how do I change the password I log into the router with?
5 REPLIES 5
Blake
Re: Sagemcom 2704N
It's your account username followed by @plusdsl.net & then your account password.
I believe the router password is set in stone on the dispatched firmware.
Eggs
Re: Sagemcom 2704N
OK.
I have changed the router password by using a link given elsewhere on these forums.
As regards the other two: my account username and account password -  what are they used for?
Eggs
Re: Sagemcom 2704N
Change the router password here:
http://192.168.1.254/expert_user.html
runhare
Re: Sagemcom 2704N
They tell the Plus Net  server that you are logged into your account and thus your inetrnet connection is authenticated and you connect! If there is no user name and password you do not connect. However your  log in should be automated via the TR69 server when the router conenects to plus net so in most cases  you don't have to enter them .
Eggs
Re: Sagemcom 2704N
I see. So they aren't something which should be changed.
