Sagemcom 2704N
- Re: Sagemcom 2704N
Sagemcom 2704N
30-07-2015 9:17 PM
Just a quick question.
In Broadband Basic Settings, what is the Broadband Username and Broadband Password used for and how can I change them?
Also, how do I change the password I log into the router with?
5 REPLIES 5
Re: Sagemcom 2704N
31-07-2015 7:21 AM
It's your account username followed by @plusdsl.net & then your account password.
I believe the router password is set in stone on the dispatched firmware.
Re: Sagemcom 2704N
31-07-2015 9:18 AM
OK.
I have changed the router password by using a link given elsewhere on these forums.
As regards the other two: my account username and account password - what are they used for?
Re: Sagemcom 2704N
31-07-2015 9:36 AM
Change the router password here:
http://192.168.1.254/expert_user.html
Re: Sagemcom 2704N
31-07-2015 7:07 PM
Quote As regards the other two: my account username and account password - what are they used for?
They tell the Plus Net server that you are logged into your account and thus your inetrnet connection is authenticated and you connect! If there is no user name and password you do not connect. However your log in should be automated via the TR69 server when the router conenects to plus net so in most cases you don't have to enter them .
Re: Sagemcom 2704N
31-07-2015 8:40 PM
I see. So they aren't something which should be changed.
