Sagem 2704N connection problems with my Sky+ connector and Three's HomeSignal bo
- Sagem 2704N connection problems with my Sky+ conne...
Re: Sagem 2704N connection problems with my Sky+ connector and Three's HomeSignal bo
23-06-2015 10:50 PM
I did read a few things that seemed to suggest I could connect my old Netgear DGN2200 to the fibre modem, but I tried that and it didn't work. Not sure if there was some configuration I needed to do to turn one of the Ethernet ports into a WAN port, or maybe I have a version that just plain doesn't do it..
Al.
24-06-2015 9:15 AM
I'm not sure but I think it might only be the v4 version that has this capability. According to the netgear kb here http://kb.netgear.com/app/answers/detail/a_id/23693/~/dgn2200v4-%E2%80%93-using-lan-port-4-as-a-wan-... it SHOULD autodetect but you can force configuration of LAN port 4 manually.
Quote I did read a few things that seemed to suggest I could connect my old Netgear DGN2200
Hope that helps ( assuming you do have a v4 ! )
24-06-2015 9:17 AM
24-06-2015 9:23 AM
24-06-2015 10:24 AM
04-07-2015 4:56 PM
Cheers,
Al
16-07-2015 6:08 AM
I'm still having problems with this router, just randomly lost connection with my phone yet my internet didn't go down at all because I was mid-skype call on my laptop so... yeah.
When are Plusnet going to either fix this or change to a completely new router, leave buggy sagem 2704N behind!
I really can't afford to get myself a new router at the moment, I certainly wish I could afford one of the Dual Band routers with decent wireless capabilities, with G.INP and preferably Wireless AC but hey now I'm being picky haha but yeah they're rather pricey.
Any advice...?
21-07-2015 2:37 PM
It kept throwing up the error "Authentication failed" when the password was 100% correct and nothing has been changed in the router.
23-07-2015 12:48 PM
Again, happened twice today already.
24-07-2015 11:11 AM
25-07-2015 5:47 AM
Firmware version: 7.273.1_F2704N_Plusnet
adie:quote
28-07-2015 7:04 PM
30-07-2015 12:55 AM
I'm also wondering if you are getting interference from some other equipment, for example a microwave oven!
30-07-2015 3:18 PM
adie:Quote
30-07-2015 3:37 PM
