Sagem 2704N connection problems with my Sky+ connector and Three's HomeSignal bo
- Sagem 2704N connection problems with my Sky+ conne...
Re: Sagem 2704N connection problems with my Sky+ connector and Three's HomeSignal bo
01-06-2015 6:58 AM
01-06-2015 7:15 AM
Quote from: Anotherone Hi alhenderson, are you giving the Skybox a fixed IP address on the LAN? Use http://192.168.1.254/expert_user.html to login. Are you on Fibre or ADS:L? That Sky help page information is not applicable to a Plusnet connection. The modulation is PPPoE on Fibre and PPPoA on ADSL and in any event can't be changed on the 2704n.
01-06-2015 8:41 AM
See the attached screen grab I took a while ago, but also note that the 2nd IP address is not part of the default settings and is something I've added whilst experimenting.
01-06-2015 6:20 PM
Cheers,
Al
01-06-2015 6:35 PM
See attached screen grabs.
01-06-2015 7:10 PM
Al
01-06-2015 8:30 PM
01-06-2015 8:55 PM
Al.
02-06-2015 7:10 AM
http://community.plus.net/forum/index.php/topic,135846.msg1210507.html#msg1210507
http://community.plus.net/forum/index.php/topic,139281.msg1227900.html#msg1227900
http://community.plus.net/forum/index.php/topic,138420.0.html
http://community.plus.net/forum/index.php/topic,138463.msg1224734.html#msg1224734
Just some of the things I quickly managed to dig out. Have a read through, you might find things and links that may help solve all the issues.
Beware playing with firmware, unless you know what you are doing. There's always a small risk of bricking it.
02-06-2015 7:41 AM
Quote from: Anotherone The following may be of some interest, I haven't followed through the detail on all of it -
02-06-2015 10:12 PM
Al.
03-06-2015 9:06 AM
Edit: I note the OP of the thread hasn't posted back, I wonder if they solved their issue? If so, their info may be helpful.
03-06-2015 7:42 PM
Al.
03-06-2015 8:56 PM
I seem to recall some similar issue like this involving powerline adapters, I'll see if I can quickly find anything.
04-06-2015 1:28 PM
