SURVEY: What temperature does your CPU run at?
- Re: SURVEY: What temperature does your CPU run at?
08-10-2008 11:39 PM
After days of infuriating failed attempts at bringing down my celeron D temperature (50 on startup, 57 after a while) I've started wondering what the average temperature is for a CPU.
So folks, what CPU do you run and what is its average temperature? What cooling do you use? (IE fan with heat sink or water cooling).
Also feel free to tell me its startup temperature and "running a while" temperature!
EDIT: You can use Speedfan to find out the temperature of your CPU. The hottest temperature it shows (they're listed numerically) is generally the CPU.
09-10-2008 12:08 AM
09-10-2008 8:14 AM
If people know how to find out, they have a better chance of responding.
What tool do you use currently?
09-10-2008 8:48 AM
09-10-2008 9:23 AM
For cooling I use a scythe mine revision B with arctic silver thermal paste.
09-10-2008 9:54 AM
Yay water. At those temps I should be able to get it a bit faster too.
09-10-2008 10:08 AM
09-10-2008 12:12 PM
Rob
09-10-2008 12:22 PM
CPU Z http://www.cpuid.com/cpuz.php
Also useful is GPU-Z which monitors your graphics card http://www.techpowerup.com/downloads/
09-10-2008 12:49 PM
09-10-2008 12:59 PM
Edit - version 4.35 does
09-10-2008 1:01 PM
There's a lot of different versions of coretemp out there, and it's regularly updated - try and grab the latest version from the home site (Oldjim's link above) rather than from any of the 3d/overclocking sites as they tend to have older versions.
09-10-2008 1:02 PM
Core 0 24c
Core 1 28c
using CPUID Hardware monitor.
Edit: Work PC
09-10-2008 1:11 PM
09-10-2008 7:21 PM
