SURVEY: What temperature does your CPU run at?
7up
Fixes: 17
Hi guys
After days of infuriating failed attempts at bringing down my celeron D temperature (50 on startup, 57 after a while) I've started wondering what the average temperature is for a CPU.
So folks, what CPU do you run and what is its average temperature? What cooling do you use? (IE fan with heat sink or water cooling).
Also feel free to tell me its startup temperature and "running a while" temperature!
EDIT: You can use Speedfan to find out the temperature of your CPU. The hottest temperature it shows (they're listed numerically) is generally the CPU.
49 REPLIES 49
artificer
Re: SURVEY: What temperature does your CPU run at?
shuttle with 'ice' cooling system, 35C; dell inspiron laptop, with cooler beneath, 38C.  without the cooler, the laptop runs at about 45C.
Happy to add some detail to this, but and idea that might be worth exploring; perhaps a link to some software which will allow people to find out the details might be useful.
If people know how to find out, they have a better chance of responding.
What tool do you use currently?
paulby
I used Speedfan to get the info.
Currently running an AMD Athlon 3100+ with Zalman fan and heatsink.  Processor sits around 54C after an hour's running. (The spec for the processor indicates that its max operating temp is 85C so it's well below that!)
Chris
Legend
Fixes: 169
Using coretemp to get the temparatures, my Q6600 is running at between 34 and 36 per core.
For cooling I use a scythe mine revision B with arctic silver thermal paste.
orbrey
<img src="http://www.binarybob.plus.com/matt/temps.png">
Yay water. At those temps I should be able to get it a bit faster too.
Oldjim
Resting Legend
Fixes: 63
With a Scythe Mine rev b Arctic Silver 5 and an Akasa Eclipse 62 case these are my results (note that the CPU has throttled down from 2667MHz
randpwar
I would like to contribute and also to find out for my own interest;  Chris, Orbrey and Oldjim - How do you get to the information you’ve displayed?
Rob
Oldjim
Resting Legend
Fixes: 63
CoreTemp http://www.alcpu.com/CoreTemp/
CPU Z  http://www.cpuid.com/cpuz.php
Also useful is GPU-Z which monitors your graphics card http://www.techpowerup.com/downloads/
7up
Fixes: 17
I'm sure I tried coretemp recently and found its limited in the motherboards and processors it can read. Speedfan can read the temperature of almost everything.
Oldjim
Resting Legend
Fixes: 63
Note that on my motherboard speedfan doesn't record the core temperatures correctly
Edit - version 4.35 does
orbrey
@okrzynska
There's a lot of different versions of coretemp out there, and it's regularly updated - try and grab the latest version from the home site (Oldjim's link above) rather than from any of the 3d/overclocking sites as they tend to have older versions.
Strat
Fixes: 565
Intel Core 2 Duo E6400
Core 0 24c
Core 1 28c
using CPUID Hardware monitor.
Edit: Work PC
zubel
My work machine:
Strat
Fixes: 565
Home PC
